load another flash movie
You do not need Load Movie event to load your Flash in Lectora. Just go Add > Object > Animation to any Lectora page. Make note of wherever you are saving your Lectora project. Make sure that the .swf file is in the images folder in your Lectora project. If you have any difficulty viewing after publishing at all, it is probably because the Flash file cannot be found.
