I'm trying to squeeze more information into a single page by using transition in and transition out on a group of objects.
This works perfectly inside Lectora but only works for the first time in a browser, subsequent times the transitioned out object does not come back in.
If I remove the transition out and just make it hide, this works fine but doesn't look as appealing.
I don't know if this is a bug or just me using the program incorrectly.
I've put a copy on youshare (File expiration date: July 25, 2011) to illustrate it better.
