Lectora SCORM settings for Cornerstone LMS
 Do you know what the completion value is that the Cornerstone LMS is expecting? THe other thing that you need to find out is the maximum score value the lms can record. This information should be available directly from the LMS vendor.
casE said:Hi all, We were wondering if anyone is exporting their Lectora projects for integration into Cornerstone. If so, could you please share the settings you use to export the project with SCORM compliance so that scores are successfully tracked. Many thanks
