Lectora Interface Color
February 23, 2006 12:00 AM
I changed very setting I could find but nothing changed the base gradient color of blue. I could change the other. Mine was always blue and some other color. MS Word tool bars were not affected. So, I am still of no help other than to say that it is likely NOT a setting you can control. You might try reinstalling it. Other than that, you should go directly to support.Running same as you except my says Lectora v. 2006 (2924). benEdited By: bpitman on 2006-2-27 16:31:43
