Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
Lectora Interface Color
@badbob
February 23, 2006 12:00 AM
The solution I've found is to disable visual themes in the shortcut to lectora. That means no fancy title bar, but at least I can bear to look at the screen.The solution I've found is to disable visual themes in the shortcut to lectora. That means no fancy title bar, but at least I can bear to look at the screen.
badbob badbob
@badbob
View Profile
More From badbob
typing numbers into the font size box
March 30, 2006 Reply 0 Upvotes
Link leaves [object]
March 21, 2006 Reply 0 Upvotes
Join The Discussion
Sign Up Login
