Lectora Integrator for Power point
I've never used Integrator, but I will say that the 775x425 seems like a wise size choice. From all my years of design for the web, I've always used the philosophy that nothing should be wider than 770 pixels. There's nothing more unprofessional (IMHO) than a site that you have to scroll left and right on. (Unless that's the design, and in that case- cool!)Granted, I use dual 1600x 1200's at work, and triples at home, so I'm down with the larger format- but you have to design for the lowest denominator. (Unless specified differently in the scope.)Oh- back to your Integrator question...I donno.JoeEdited By: CDC_Joe on 2007-10-11 14:16:49
