Lectora 2007 SP4 not running in Saba 3.5
February 12, 2008 12:00 AM
It is hard to say what exactly could be causing the issue. Most likely it is some issue your Java plug in is having with the Java applet. Do you know if you LMS also requires the use of Java in its environment? We recommend using SCORM content if it is on a different server or if that is not an option, as mentioned above, then use the JavaScript Title Manager with the cross domain redirector to avoid issues with how the Java plug ins handle both the LMS and the course content in your specific environment. If you believe this to be a bug in Lectora, simply email support@trivantis.com with login information and we will be happy to test the content as well as upload some of our own for testing purposes. We just released SP5 for the 2007 version but not sure this will address your issues since it seems to be something environment specific but definitely worth a try.It is hard to say what exactly could be causing the issue. Most likely it is some issue your Java plug in is having with the Java applet. Do you know if you LMS also requires the use of Java in its environment? We recommend using SCORM content if it is on a different server or if that is not an option, as mentioned above, then use the JavaScript Title Manager with the cross domain redirector to avoid issues with how the Java plug ins handle both the LMS and the course content in your specific environment. If you believe this to be a bug in Lectora, simply email support@trivantis.com with login information and we will be happy to test the content as well as upload some of our own for testing purposes. We just released SP5 for the 2007 version but not sure this will address your issues since it seems to be something environment specific but definitely worth a try.
