Lectora 2005 problems printing png images
AnneD,Another check you can do is to open the problematic image file directly in IE (without using Lectora at all.) Open IE and drag your .png file into the IE window. This should open the image within the IE browser. Now try to print it. If it doesn't print than this is a bug within IE's print function.Edited By: aaron on 2006-5-23 0:16:42
