Lectora 17 Seamless Play help
December 27, 2016 12:00 AM
Hello everyone.
I downloaded and installed the Lectora 17 demo.
I also did a couple of examples to see the new options that the program brings.
When I try to publish the content with the Seamless Play option, the content does not work, the page goes blank.
If I remove the option and publish, everything works correctly.
I installed on a computer that had not had previous versions of the program installed, to discard that it was generating problems having more than one version at a time.
Hopefully they can help me to check what is happening.
The Seamless Play option is very useful, hopefully I can be guided to make it work.
Thank you, as always, for the help.
Greetings.
How are you previewing it? It will only work if you run it via a webserver. So you either have to preview it from Lectora built-in server via Lectora preview or upload it somewhere to the web / LMS / ReviewLink etc. Simply launching from your hard disk will not work.
We've had the same type of issues while published out here. We have had issue where the course goes to the next page but items from the previous page are still showing. We have also noticed the transitions don't work or move super slow, like 60 seconds for a fast fade in to finish.
We have reported these issues already. Publishing with Seamless off fixed these issues.
Hi Mario and Lazaro. Could I get a copy of your title(s) that are having problems? It could be running from with a web server like Sergey said or it could be a scripting issue. But if it is a bug in Lectora, I would really like to identify it so we can get it fixed in a service pack.
The URL to upload a title is http://trivantis.com/contact-support/. If you do upload it, please reference this thread in the message field and reply to this message and somebody on my team will look into it.
