Lectora 11 Interface questions
February 12, 2014 12:00 AM
Hello, I'm currently trying Lectora 11 (coming from Lectora 9) and I'm just puzzled by the inefficiency of the interface. Am I missing something?
#1 Properties
Is there no way to look at the properties outside of the ribbon (pane/window as it used to be)?
Searching the forum, it seems that if the ribbon is forced and that I also have to hover over a very little arrow to get the HTML object name every single time (frustrating enough).
#2 Actions
Again, this also used to be a docked/floating window that was easy to read. Now, it's in the ribbon, HORIZONTALLY, with images? I found the Action Pane and it's already much easier to read, but is there a way to edit the actions in the Action Pane?
Overall, I can't see why you'd design your entire interface to have users reading horizontal information at the very top of the screen.
Discussion (4)
Lectora has been obviously designed with slower, less tech-savvy users in mind. The horizontal ribbon interface with pretty pictures and such is aimed at them. Pro developers are a minority, so nobody cares too much about their needs. "You want to easily see html object names? Pfft!"
It appears that they modeled after MicroSoft to make it easier for people who use those tools.
@ssneg 59923 wrote:
Real developers use Adobe CC Edge, Sublime Text or Notepad++ ;)
Back in the days Vi was my tool of choice...
