key press and scorm
Using Lectora 2006, I added two actions to go to the next or previous page based on the user pressing the right arrow or left arrow key respectively. This works fine when published to HTML.These actions do not work when published to SCORM.To get around this, I wrote javascript functions and added them to the index file frameset that is the launch page for the SCORM version. In my case the file is called a001index.html. This works fine.I have 2 questions:1. Is is possible to use Lectora actions to navigate between the next and previous pages using the arrow keys within a SCORM environment?2. If not, is there a way to include custom javascript within the index file frameset (the launcher for the SCORM course) automatically, instead of having to add it manually?Thank you.Brian
