js not working for Flash8
I had the same issue - you will need to change the security settings on your local computer for the flash calls to work. If you try the same publish across a network or posted on a site then the calls should work with out any issues.I had the same issue - you will need to change the security settings on your local computer for the flash calls to work. If you try the same publish across a network or posted on a site then the calls should work with out any issues.
