Howdy!So a few months ago we were using a splash page made in flash and the buttons that lectora generated to advance to the next page. Recently we found the awesome ability to add this function into flash itself:on (release) {getURL('javascript:trivNextPage()');}It works fine except for one thing. I'm using a loadMovie actionscript to basically put a blank swf into our course. The script then calls upon an external swf to fill that blank swf. This is all transparent and it acts as if the swf is actually embedded into the lectora file. The problem is now the script above will not advance the page. The button clicks but it's like a dead battery in a car, it won't turn over. I've tried a few various things but I wanted to post this here in case it's not possible to fix or if there's an obvious "DUH!" solution to this.I appreciate any thoughts you have and I can gladly post more info if you need it. edit:Also, when I click to preview this in Lectora it will act as if it wants to advance but it cant obviously since it's not published. It's only once I upload to our LMS that this occurs. I might have answered my own question as to what the problem is But still if anyone has experience with this issue that'd be ever so helpful.thanks again!Edited By: laserfloyd on 2006-9-21 14:51:51
