Are you getting any javascript errors when running the content? No How are you progressing thru the content ... using the normal Lectora navigation ... or are you doing something special with external HTML or javascript? I have been using the "Add Action" function button and it has been working fine during all of my trial runs (however they were all using the Publish to Single File Executable). Can you send me one of your SCORM packages so I can test it on our own LMS (CourseMill) to see if there is anything glaring that stands out? YES, if you could try this on your LMS I would so greatful! How do I go about sending you the file?
