Issue with bullet point alignment in "CC/Transcript" window
January 21, 2016 12:00 AM
Hello,
I am facing a issue where after publishing the course the alignment of the bullet points in "CC/ Transcript" window goes off after publishing.
I am using Lectora 12.0 version and here are the steps I am following to resolve this issue, however still couldn't find any luck on this.
- Remove Bullet list from word
- Copy text to noted pad
- Copy paste text into Lectora
- Use Lectora bullet feature
I have attached the video indicating the issue I am facing currently. Can you please help me on this?
Regards,
Abhijeet
Discussion (6)
That's the usual problem with bullet point alignment in Lectora... Although it seems worse again from v11 to v12. It can be "solved" by using a table with a narrow left column for the bullet points and a second column for the text. Or check "Convert to image" in the textfields properties.
Tim
Hello,
Somehow video couldn't got uploaded. I am attaching the screen captures of the issue.
Regards,
Abhijeet
Instead of your steps 2. and 3. you can paste "unformatted text" to Lectora by using [Ctrl] + [Shift] + [v]. There is no video to see the problem, but bullet point alignment has always been difficult...
Tim
I am using Firefox 44, IE11 and Google Chrome 48.
Thanks for suggesting these approaches. I will try these and will let you know the results.
