Issue with a Click to Reveal Variable
August 21, 2019 12:00 AM
I've created a page where learners need to click on 11 different buttons to advance to the next page. They can click the buttons in whatever order they want. After a learner clicks one of the buttons a check mark will appear beside the button to let the learner know they don't need to click on it again.
The issue I've ran into is if the leaner decides to click on the 10th or 11th button first then a check mark will appear beside that button as well as the first button (which they have not click yet).
I have set the Actions as the following....
Show: Check 10
Conditions: IF
Variable: var_Pg7_CTRStatus
Relationship: Contains
Value: _10
Show: Check 11
Conditions: IF
Value: _11
Can anyone suggest a way to keep the first check mark from appearing until the learner clicks on the first button?
Thank you,
Anthony
Discussion (4)
I appreciate the feedback, Adam.
Thanks Tim! This morning I used _010 and _011 and was able to make it work.
When you click and add "_10" the variable would also contain "_1". In most cases like this it's easier to not use numbers. Just add "a" for the first and "j" for the tenth to have unique values for each button.
I know a lot of authors will use a delimiter at the start and end for these types of conditions.
I just did an interaction where I used:
!Q1! !Q2! ... etc
Then when comparing or doing a modify variable 'add' or 'subtract' I would always use the complete item
if contains !Q1! or add !Q2! or subtract !Q100! etc
