Issue Flash in IE and Lectora 9
January 5, 2009 12:00 AM
I'm having the same issue. I've got a title that, if published in v8, works fine, but breaks on IE if published in v9.Trivantis support was unable to duplicate the problem from a file I sent them, but I can reliablly duplicate it here.The cause definitely seems to be the change in the way v9 writes it's embed code for Flash, which as you pointed out is different from v8.The only reliable workaround I've found so far is to go back to v8 for publishing. Bruce
