Interactivity Problem
hamish said:I have created some interactivities in Lectora, but they're loading behind my flash pages (I can see part of the popup and part is hidden behind the flash page). I've tried out all the options in the Layering option ("Bring to Front/Send to Back" and "Up one layer/Down one layer") but it just doesn't work. The funny thing is that initially (2days ago) it had worked without a hitch but now it's just being fussy.
David: you have to set a parameter in the flash called wmode: transparent. Go to the flash object property box in lectora >> parameters. enter wmode >> transparent. This sets the z-index of the flash to 0 as well as make your flash bg not appear
