Interactive item problem
Yes. What is happening is that when you show the text box, it makes the browser think that you have moved the mouse because it is now shielded from the graphic by the text box. So the graphic runs the Mouse Exit action which hides the text box. Now the cursor is over the graphic and bingo, it shows the text box and repeats this crazy cycle.
Solution is to cover them both with a transparent button or a transparent .gif which is ON TOP of them both. You will have to turn on Always on top AND position below them in the left pane. Then put your actions on the button or transparent graphic.
