Inserting a Section between two sections
April 12, 2006 12:00 AM
What version of Lectora? Makes a big difference. 2005 the only way to resequence the sections was to drag them in reverse order and drop them on top of the chapter. So if you want section A, the B, then C you need to drag C on to the chapter, then B, then A -- kind of like stacking pieces of paper.If you have 2006, you can drag the section to wherever you want it. FIRST to make life a lot easier, collapse all sections so all you see is the chapter and the objects at the ONE level below the chapter level like the sections -- no pages inside the sections. Then when you drag a section, a black line will follow you as you drag. When it is over another section, that section will show selected and it will drop INSIDE that section. If the line is between sections, it will drop between the sections. You can drag it to the end too. cheers, benEdited By: bpitman on 2006-4-11 17:48:44
