Info pane is not lined up with edge of slide
January 14, 2012 12:00 AM
Ok, I see what's happening here. If there are 12+ key slides (with the presenter pane enabled), or 17+ key slides (with the presenter pane disabled), the off centered gray bar actually delimits the left side of the vertical slider. This makes sense, since most (if not all) presentations will meet these minimum key slide parameters, and it is actually very polished looking!
G
