Info pane is not lined up with edge of slide
January 14, 2012 12:00 AM
Further testing shows that the same behavior and parameters apply to the thumbnail view, but there will hardly ever be 12+ attachments to a presention so this pane looks unprofessional because it does not hide the gray slider edge. Interestingly, the speaker notes pane works exactly as expected. If there is no need for a slider, none is presented and the text wraps out to the left edge of the slide, without the delimiting gray bar. I hope that this behavior can be fixed to be consistent on all panes in an upcoming update.
G
