Incorrect Entry in Help - Adding Vertical Scroll to an Image
June 16, 2017 12:00 AM
According to the Help (Lectora Online Information Center); the following entry in the section Managing Titles undefined Adding a vertical scroll to the image. It says that in the Appearance group you can enable the Vertical Scroll check box, but that option does not exist.
Discussion (1)
Thanks for the heads-up! We appreciate the catch.
By the way, if you are looking for a way to scroll an image, check out the sample posted by my colleague Wendy Miller: http://community.trivantis.com/shared-content/scrolling-images-within-text-blocks-example/
