Inconsistent Test Reporting. HELP PLEASE
June 25, 2009 12:00 AM
We are having serious issues with inconsistencies in test reporting. We have Coursemill 4.0 and are creating our tests in Lectora v9.2.
We have been creating these tests from a template for the past 2 years and only just now have started to run into this issue.
Sometimes all student test interactions will be recorded successfully. Most times not.
Sometimes a student’s “status” completion report shows “passed” with score recorded. Sometimes it will show “incomplete” with a “0” score. Even if they have passed the test.
The only way we have been able work around this issue to prove students have completed and passed tests is to implement a certificate page they must print that displays both their test score and a dynamically generated a confirmation code generated from their login ID.
I’ve read the posts regarding eliminating quotes (‘) and (“) in test questions that affect reporting. I am currently looking into that, but would that explain the intermittent success/fail of interaction reporting?
Our tests are used for highly critical functions that are regulated. We absolutely must be able to capture all scores, scores, and test answers 100% of the time.
Is anyone else having this problem? Any help would be greatly appreciated.
