Im having a big problem @ slow page changing.
August 5, 2011 12:00 AM
Hello!
At our company, we use Lectora Inspire to develop an alternate kind of e - learning content.
And to do that, we need to sync a massive load of short pieces of audio, within transitioning text.
In the very beginning, our project was very small, and everything was fine till the content got bigger.
And as big it is becoming, as slow is our developing suit (Lectora Inspire) is getting . Not only the suit, but the product published too.
But i know, that piece of infrmation wont help you guys to help me, but, i got something else:
- We use all audio encoded in 64k Constant Bit Rate, Mono and in MPEG Layer 3 format (mp3)
- We have all images as JPEG, exept the transparency ones. Int that case we use PNG.
- We use O.O.(Object Oriented) techniques as provided, specially Inheritance,We use it a lot!
- Our images are the shortest possible to mantain quality.
- We use lectora in computers with 64 bit OS, Core i3 4 gigs of ram.
- We use groups of objects, to be able to use Skip buttons easily.
- This project will be Published to EXE as its primal objective (CD-ROM) and we have a strong demand to publish it on a SCORM based server.
If any of you got trhu any project as big as this, and/or have a solution for my problem, we would apreciate it a lot.
Btw, the developing of this project using lectora, depends on this particular issue.
Thanks in advance!
