Html publishing problem
Thanks to all for your responses. After downloading the service packs, found that problem appears to be with the version of Java I was using. Rolled back a version (so is same as what I have on another PC with Lectora) and it seems to work fine now.Thanks to all for your responses. After downloading the service packs, found that problem appears to be with the version of Java I was using. Rolled back a version (so is same as what I have on another PC with Lectora) and it seems to work fine now.
