I want to create an menu which links to different AU. When I publish it, it pops an error message "The SCORM/Web-based standard restricts the author from creating links between multiple AUs. On the Web, the transitioning between AUs is a function of the LMS".
Do you know have some ideas about that? Thanks a lot in advance.
