How to mute contents of a web window
June 6, 2016 12:00 AM
Hi there
Discussion (4)
The html name of the "Web Window" element is the id of the DIV the iframe is in. The id of the iframe is the html name + "iframe" so it's something like "webwidget74iframe". This may be useful when trying to target the frame with jquery.
The easiest way to communicate with a frame in javascript is calling it by its name. The default name of a Lectora Web window is "Trivantis_WebWindow". To use the standard "Mute media"-action on all media in an iframe you can:
On: Click
Action: Run javascript
Javascript:
Trivantis_WebWindow.updateFLVPlayer(true);
Use "false" to unmute.
Tim
Hi Daniel,
A sample would help, especially because its a bit unclear what content to mute.
You probably first need to target the webwindow...
var myWebwindow = document.getElementById("webwindowHTMLName");
and then you can act upon it...
myWebwindow.mute();
Regards,
Math
Thanks Math
The web window contains a streamed video player from my Department.
