How to Get Variable and Set Variable Flash Commands
I've used AS2 files in the past with Lectora to access variables easily. Now that I'm trying to use the same Flash Commands on an AS3 swf file, problems are apparent. When using Get Variable in Lectora, the error pops up, "Invalid Flash Variable Name!!" in the Lectora Enterprise Edition. The Set Variable command just seems to do nothing. Should these commands work with AS3 swf files or is there something special you have to do to get the same AS2 usability out of Lectora?
