How to add an animation that will
Building on Hemingway's solution, you really don't need to have a show for both items. You could put the animation on top, not visible, the end frame on the bottom, always visible. Then you only need one action to show the animation and maybe anothe to play it if flash. When running, the default last frame is always showing so there is no need for an action to show it.Also, do you really need the animation on all the pages or just the first one? If just the first, put the last frame at the title level and the real animation on the first page overlaying the last frame. No actions required for this solution.
