How do I create a highlight box??
October 9, 2009 12:00 AM
I use the animated gallery objects from Captivate (usually "C:Program FilesAdobeAdobe Captivate 4GallerySWF Animation") in my Lectora courses often. I like the pointing Human Hand, Right Mark, and Wrong Mark. They add a little visual humor to the course. Add a buzzer or a dinging bell noise, and you have the beginnings of a great game!
Just import them as you would any other swf object. Then set the wmode parameter to Transparent.
To see the transparency, you need to publish the course. Looking at it in any other mode will show the white box around the swf object.
