Hotkeys for Flash Animations
July 17, 2008 12:00 AM
The controls work fine if I click on the controls. Just having trouble with the hotkeys. I'm not sure if there is suppose to be a standard set of hotkeys or whether there is suppose to be a place where they can be defined. For example, one resource I found says that the space bar is suppose to toggle between play and pause.The controls work fine if I click on the controls. Just having trouble with the hotkeys. I'm not sure if there is suppose to be a standard set of hotkeys or whether there is suppose to be a place where they can be defined. For example, one resource I found says that the space bar is suppose to toggle between play and pause.
