Hotkeys for Flash Animations
It could but i would say that you are safer running it in preview than HTML, because of brower and security settings. However, publish it to HTML and try. The reason why is if the controls are javascript based than only publishing it will provide the library needed to run the script.And what is happening to the animation. Is it playing in a loop, not playing at all and stuck on a single frame, I need some more info.Edited By: kballard on 2008-7-17 15:34:51
