Hot spot questions
Thanks Tee - yes - I had looked at that - I was hoping there was a means of using a userdefined transparent hotspot with in the native lectora question template but I now realise it doesn't work like that. Thanks Tee - yes - I had looked at that - I was hoping there was a means of using a userdefined transparent hotspot with in the native lectora question template but I now realise it doesn't work like that.
