Within the hotspot question properties you have to import the hotspot image (your screen shot image). The hotspot test question is basically a visual multiple choice question and the actual hotspots are radio buttons that you can place within your screen shot image.Within the hotspot question properties you have to import the hotspot image (your screen shot image). The hotspot test question is basically a visual multiple choice question and the actual hotspots are radio buttons that you can place within your screen shot image.
