Highlight Current Section in Menu
Looks like that is the case. I just changed one of mine that works fine w/regular frame to transparent and had the same problem you are having. Too bad. Looks like a bug. Suggest you submit it to support@trivantis.com.Looks like that is the case. I just changed one of mine that works fine w/regular frame to transparent and had the same problem you are having. Too bad. Looks like a bug. Suggest you submit it to support@trivantis.com.
