Help with Test/Questions
Have you tried reading about tests in the Help function of Lectora? It would probably answer your questions with a lot more details than we could on this forum.As far as adding the questions one at a time, that is the only way to create a test in Lectora. You can however select muliple items (multiple questions) and use the layout function to align them all at once if you need to.
