Help with Test
November 14, 2008 12:00 AM
What exactly is the failed-page? Is it a pop-up screen or is it some page you get warped to?What I do is the following:I create a question and make sure the feedback is on with right answer in the question itself. Something like "You are right, because material A and B are both liquids.". Next up, I make sure (through inheritence on the page) the next button is gone. The I copy-paste a new next-button on the page. That button lets you go to the next page, as the old button would, but this time I give it a condition. Conditions can be found on the second (or third) tab of the button. The condition with my questions is usually something like "Question 15 - IS CORRECT". This means that the action will only work if they answered Question 15 correctly.This should pretty much solve your problem.There are more than 2 ways to solve this issue within Lectora itself. Using common sense and some "programming" will get you there I guess. If you still can't figure it out, other smart people will prob. be able to help you out (such as Dr. Lectora Ben Pitman).Good luck!
