Help with Querystring
March 26, 2009 12:00 AM
I have a function that I'm calling on clicking the done button
My actual function is as follows:
function goNext() {
window.top.location.href='/onlinelearning/trnmnu.asp' + location.search + '&moveForward=1'
If I view the properties of the page that the button is now opening, the URL is: /onlinelearning/trnmnu.asp&moveForward=1
It should be something like: /onlinelearning/trnmnu.asp?roleid=909&caseid=1723&presid=8907&moveForward=1
The querystring (?roleid=909&caseid=1723&presid=8907) is only available on the first page of the title because on Next, Lectora loads a separate page. I need to be able to capture the "?roleid=909&caseid=1723&presid=8907" in a variable and then pass that variable back into the function when the user reaches the last page and they click the Done button.
I'm thinking an action:
On: Show
Action: Modify Variable
Target: QueryLocation
Value: ?
Modifcation: Set Variable Contents
Done button function:
Action: Go To
Target: Web Address
Web Address: javascript:goNext(QueryLocation)
Header Script Function:
function goNext() {
window.top.location.href='/onlinelearning/trnmnu.asp' + QueryLocation + '&moveForward=1'
Would something like this work?
Where do I establish "QueryLocation" as a variable? I have a function that I'm calling on clicking the done button
function goNext() {
On: Show
Value: ?
Action: Go To
Target: Web Address
function goNext() {
