Help me to read text from box
May 6, 2007 12:00 AM
So basically you want interaction real-time? This can be done with javascript in a way, but I'm not really good with that myself.Other than than, you need a form of a connection to a PC, and I'm not really sure that Lectora can provide you with that.Try search some javascript toturial sites for a way to connect, and try to add/remove things you need.
