Help: Index for Randomized Test
October 5, 2007 12:00 AM
The questions in a randomized test get randomized each time the learner enters the test. This does make it a bit difficult to make it make sense to the learner.You could create a page with 9 buttons like you show above, each goes to the respective page. Then you just need 9 variables, one for each question, that the learner can set to bookmark the page. Now, the hardest part is that Question 1 the first time they enter the test might be Question 4 the next time. It would still use the same variable and your bookmark should still work, just the labeling would be a bit wierd for the learner.
