Help in my test
May 6, 2007 12:00 AM
What Lectora do you use? For a solution, you could do the following:1. create a question with the question being something like "question 1".2. make the questionbox which holds the question text transparent.3. create a new textbox with the question in it, and place it on top of the original boxJust a suggestion, but it might work.Edited By: Ludo on 2007-5-7 3:38:31
