We had similar problems when publishing to HTML (although images looked fine in the single-file executable version). We changed to compression to the lowest level possible and that didn't help much. I do tons of screen shots for my Lectora courses and found that pasting the screen shots into Adobe Fireworks (we have CS3) and saving those as jpgs worked the best.
rmitchell said:All ideas/suggestions appreciated - We are having significant and on-going image clarity issues when publishing our Lectora units to HTML, SCORM or WebCT. We've set our compression level to lowest possible We've stopped resizing images within Lectora We will get image issues - but not consistently and that is what is driving us crazy. One developer can input 3 images the exact same way - 2 will be clear; 1 blurry. ???? Our latest "Eureka" was publishing directly to our hard drives (and not on the company server) - that seemed to fix one developer's problem, but not the other one. Frustration is setting in. Any advice or tips on how to either fix or work around this "blurry image" issue? Thanks all!
