Have you tried turing off compression all together?
Also, i have had this issue when using the zoom feature in Lectora. I would paste images. Then somewhere else, zoom in to place something or view something, zoom back out, and poof, ALL my images were fuzzy on output. Luckly i had backups prior to using the zoom. If you have used the zoom, create a copy of the file, export the xml, create a new file, import the xml, and republish to see if you still have the issue. That also worked for me.
rmitchell said:All ideas/suggestions appreciated - We are having significant and on-going image clarity issues when publishing our Lectora units to HTML, SCORM or WebCT. We've set our compression level to lowest possible We've stopped resizing images within Lectora We will get image issues - but not consistently and that is what is driving us crazy. One developer can input 3 images the exact same way - 2 will be clear; 1 blurry. ???? Our latest "Eureka" was publishing directly to our hard drives (and not on the company server) - that seemed to fix one developer's problem, but not the other one. Frustration is setting in. Any advice or tips on how to either fix or work around this "blurry image" issue? Thanks all!
