Hello, I'm a BRAND NEW user... so sorry if this is a simple question. I'm hoping it is a simple answer. But, when I publish to html, then I go and click on the "index.html" file, the page that loads isn't the full page (isn't what I should see). The surrounding images and buttons aren't there. It is just the text from page one. What file is the "main" file that loads all pieces in the published content? (i.e. I'm posting on our work Intranet and want to send out a "link" for users to click on so that they can access the E-Learning").I currently use Captivate, which creates a single file that users click on. However, I can't seem to create this single link with Lectora? Hopefully there is a simple answer. :) Thank you!
