Hi Kevin,Do you know if I can publish an Executable to SharePoint? (MOSS 2007)? Thanks. I am not knowledgeable about SharePoint, so I cannot help you there.Since it's a document management tool, I assume you could upload .EXEs. Since SharePoint is not intended to be a file server (at least, according to Wikipedia), I don't imagine that it deals that well with people accessing the executable. They could download the latest copy, if I understand SharePoint correctly. Sorry I'm not more helpful. Good luck.Kevin
