GotoFrame doesn't go to frame in Captivate swf
I'm trying to set my swf file to a particular frame number but it is not working. The swf appears to do nothing. I've kept it simple with a button with the following action:
- Action: Flash Command
- Target: Animation_Name
- Command: Go To Frame
- Number: 152 (but any number doesn't work)
I create the swf using Captivate. Does that matter? Do I need to call another Flash command after setting the frame? Thanks for your help.
