Google Drive Submit Test. problem greater than 50 questions! Help.
I am having a problem with Google Drive as I have a test with 180 questions. I have updated the Lectora template and added more questions but it seems to not enable me to post more than 54 maximum. I keep getting an error that it cannot find. Has anyone else experienced this?
Works great with 50 questions or less.
Discussion (19)
[ATTACH=CONFIG]515[/ATTACH]
suddenly it cannot contact host?
What error are you getting?
Apparently you're hitting the limit of concurrent requests to Drive API. Requests beyond limit are rejected. Looks like Lectora does not discriminate between reasons for rejection, so instead of retrying the failed requests, it gives up and produces the error.
It says right here: "only 50 people can edit a document" - https://support.google.com/drive/answer/2494827?hl=en
You should contact Lectora developers so they can amend the code for future versions. It should fire off the questions in batches of 50.
Also see this: https://developers.google.com/drive/handle-errors
I have a strong feeling that Lectora submits all questions at once. Each connection (stream) is an edit request for a number of cells, basically. The coincidence is too exact to ignore.
I'd test this, but I don't want to create a Google form and over fifty questions in a title.
Why would a limit of sharing with "50" users, effect the data posting limit of "50" items?
Well okay, I went ahead and built a title with 60 questions. When submitting to Google Forms, the server responds with "414 Request-URI Too Large" header. In other words, the string that Lectora sends is too long for the Forms to process.
The string is formed like this:
https://spreadsheets.google.com/formResponse?key=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx&
entry.0.single=studentname&
entry.1.single=%28not%20answered%29&
entry.2.single=%28not%20answered%29&
entry.3.single=%28not%20answered%29&
entry.4.single=%28not%20answered%29&
entry.5.single=Choice%20Three
...and so on.
So it includes the actual answer text. If your answer options are long, you might run out of URI length quicker than 50 questions. I just built a title with 10 questions and some really long answer options, and got the same error. I guess the 50 was just a coincidence.
I'm sure Lectora could split the submit string into several if they knew about this issue.
I appreciate you going above and beyond the call of duty on this. Thank you. I will submit your findings to Lectora and see if we can get a fix. Thank You again!!
Something again that really bothers me is that when publishing to scorm - "SUBMIT TEST RESULTS TO EMAIL"!! This drives me crazy as you have to disable Java Title Manager - and it still does not function properly. This would be the ideal solution to fix in Lectora and MANY, MANY people have asked for this. What a great world it would be if you could simply have the learning unit email the test results to ANY email address you desire.
The funny part is that ARTICULATE has this function and it works! Its not the greatest submit as it is a pile of text you have to decipher but if Articulate can program this to function, I am pretty confident Lectora could program this function that works and is not HELL to pass through the IT departments security, having email installed on the server, CGI scripting, etc.
The limit of length of the string submitted is something that is imposed by Google, there won't be any way to work around it. Submitting the data in chunks will be interpreted as multiple test submissions, so that wouldn't work either.
Would it be possible to break your 180 question test up into multiple tests, each of which submits to a different Google Form? That way, each set of test results would not be longer than allowed by Google. It also might be a nice way to break up a long test for the user.
So I tried breaking up the test into 4 tests with approx 40 to 50 questions but to no avail as it is not the amount of questions, its a data limit. So therefore you have no aspect of when your limit is going to be as some of the answers are 3 sentences long. I hope I can somehow use the GET or POST method to work for me.
I have a VBscript file that uses persits.mailsender to send emails using the submit to custom script option. Someone posted it here a long time ago and I've made a lot of changes since then, but it works for us outside of an LMS. I think your server would need to have persits or something equivalent. I know nothing about that aspect of it, just that our IT guys said it used persits.
The primary problem is that there is no way of knowing when you hit this limit. As I demonstrated above, you can hit it with only 10 questions (provided they have very long answers).. Lectora could at least estimate the potential length of the URI string and warn users when publishing such projects. It does warn everyone about 250 Kbyte large images (WHY?), so why not do this, too.
Also, here is a hint to Lectora:
You can use POST (not GET) to post data to Google Forms. It has no length limit (well, okay, there could technically be a 2Gb limit, but 2Gb is PLENTY of text data :))
I just checked, it works like a charm. I submitted a quiz response of around 1.5 Mb (that's more than your average Harry Potter book! :))
Btw, this could also solve mgilbert's problem right now, only we'll have to write a custom script that submits these variables instead of Lectora's standard function.
Does this solution have to be custom programmed for every question, every Assignable Unit test? Or once you make it can you library it and add to any course without more customized programming?
The original part of this Thread about posting to Google Drive Data Limits is still not resolved, nor have I heard from Lectora Support? I wish I knew why.
It was originally set up so that it had to be different for every test, but I recently revamped it to work for any test by pulling in the questions and correct answers that are passed from the XML file.
The code below works for up to 25 questions. You can add as many as you need for your largest test, but smaller tests work even with the extra variables included here. It sends an email (replace the email addresses first) showing only the incorrect answers. I left some variables in the code that are specific to our modules and server so you might want to remove those references, but they shouldn't cause errors. I name all our tests "Module test" so that it can find the test score each time.
Include ALL Variable Values must be checked.
<%@ Language=VBScript %>
Dim strBody
fn=Session("cFirstName")
ln=Session("cLastName")
em=Session("cemail")
un=request.form("name")
t1=request.form("_TestTime")
t2=request.form("_TestTime2")
ts=request.form("Module_test_Score")
ctn=request.form("CurrentTitleName")
ag=request.form("_addressgroup")
q1=request.form("Question1")
q2=request.form("Question2")
q3=request.form("Question3")
q4=request.form("Question4")
q5=request.form("Question5")
q6=request.form("Question6")
q7=request.form("Question7")
q8=request.form("Question8")
q9=request.form("Question9")
q10=request.form("Question10")
q11=request.form("Question11")
q12=request.form("Question12")
q13=request.form("Question13")
q14=request.form("Question14")
q15=request.form("Question15")
q16=request.form("Question16")
q17=request.form("Question17")
q18=request.form("Question18")
q19=request.form("Question19")
q20=request.form("Question20")
q21=request.form("Question21")
q22=request.form("Question22")
q23=request.form("Question23")
q24=request.form("Question24")
q25=request.form("Question25")
a1=request.form("Answer1")
a2=request.form("Answer2")
a3=request.form("Answer3")
a4=request.form("Answer4")
a5=request.form("Answer5")
a6=request.form("Answer6")
a7=request.form("Answer7")
a8=request.form("Answer8")
a9=request.form("Answer9")
a10=request.form("Answer10")
a11=request.form("Answer11")
a12=request.form("Answer12")
a13=request.form("Answer13")
a14=request.form("Answer14")
a15=request.form("Answer15")
a16=request.form("Answer16")
a17=request.form("Answer17")
a18=request.form("Answer18")
a19=request.form("Answer19")
a20=request.form("Answer20")
a21=request.form("Answer21")
a22=request.form("Answer22")
a23=request.form("Answer23")
a24=request.form("Answer24")
a25=request.form("Answer25")
c1=request.form("CorrectAnswer1")
c2=request.form("CorrectAnswer2")
c3=request.form("CorrectAnswer3")
c4=request.form("CorrectAnswer4")
c5=request.form("CorrectAnswer5")
c6=request.form("CorrectAnswer6")
c7=request.form("CorrectAnswer7")
c8=request.form("CorrectAnswer8")
c9=request.form("CorrectAnswer9")
c10=request.form("CorrectAnswer10")
c11=request.form("CorrectAnswer11")
c12=request.form("CorrectAnswer12")
c13=request.form("CorrectAnswer13")
c14=request.form("CorrectAnswer14")
c15=request.form("CorrectAnswer15")
c16=request.form("CorrectAnswer16")
c17=request.form("CorrectAnswer17")
c18=request.form("CorrectAnswer18")
c19=request.form("CorrectAnswer19")
c20=request.form("CorrectAnswer20")
c21=request.form("CorrectAnswer21")
c22=request.form("CorrectAnswer22")
c23=request.form("CorrectAnswer23")
c24=request.form("CorrectAnswer24")
c25=request.form("CorrectAnswer25")
strBody=""
if ts = "100" then
strBody=strbody & "There are no incorrect answers for:
else
strBody=strBody & "Below is the listing of all the incorrect answers for:
end if
strBody=strbody & "Name: " & un & "
strBody=strbody & "Logged in as: " & fn & " " & ln & "
strBody=strbody & "Email: " & em & "
strBody=strBody & "Test Score: " & ts & "%" & "
strBody=strBody & "Time to complete reading module: " & t1 & "
strBody=strBody & "Total time to complete module and test: " & t2 & "
if a1 <> c1 then
strBody=strBody & "Question 1: " & q1 & "
Trainee answer: " & a1 & "
strBody=strBody & "Correct answer: " & c1 & "
end if
if a2 <> c2 then
strBody=strBody & "Question 2: " & q2 & "
Trainee answer: " & a2 & "
strBody=strBody & "Correct answer: " & c2 & "
end if
if a3 <> c3 then
strBody=strBody & "Question 3: " & q3 & "
Trainee answer: " & a3 & "
strBody=strBody & "Correct answer: " & c3 & "
end if
if a4 <> c4 then
strBody=strBody & "Question 4: " & q4 & "
Trainee answer: " & a4 & "
strBody=strBody & "Correct answer: " & c4 & "
end if
if a5 <> c5 then
strBody=strBody & "Question 5: " & q5 & "
Trainee answer: " & a5 & "
strBody=strBody & "Correct answer: " & c5 & "
end if
if a6 <> c6 then
strBody=strBody & "Question 6: " & q6 & "
Trainee answer: " & a6 & "
strBody=strBody & "Correct answer: " & c6 & "
end if
if a7 <> c7 then
strBody=strBody & "Question 7: " & q7 & "
Trainee answer: " & a7 & "
strBody=strBody & "Correct answer: " & c7 & "
end if
if a8 <> c8 then
strBody=strBody & "Question 8: " & q8 & "
Trainee answer: " & a8 & "
strBody=strBody & "Correct answer: " & c8 & "
end if
if a9 <> c9 then
strBody=strBody & "Question 9: " & q9 & "
Trainee answer: " & a9 & "
strBody=strBody & "Correct answer: " & c9 & "
end if
if a10 <> c10 then
strBody=strBody & "Question 10: " & q10 & "
Trainee answer: " & a10 & "
strBody=strBody & "Correct answer: " & c10 & "
end if
if a11 <> c11 then
strBody=strBody & "Question 11: " & q11 & "
Trainee answer: " & a11 & "
strBody=strBody & "Correct answer: " & c11 & "
end if
if a12 <> c12 then
strBody=strBody & "Question 12: " & q12 & "
Trainee answer: " & a12 & "
strBody=strBody & "Correct answer: " & c12 & "
end if
if a13 <> c13 then
strBody=strBody & "Question 13: " & q13 & "
Trainee answer: " & a13 & "
strBody=strBody & "Correct answer: " & c13 & "
end if
if a14 <> c14 then
strBody=strBody & "Question 14: " & q14 & "
Trainee answer: " & a14 & "
strBody=strBody & "Correct answer: " & c14 & "
end if
if a15 <> c15 then
strBody=strBody & "Question 15: " & q15 & "
Trainee answer: " & a15 & "
strBody=strBody & "Correct answer: " & c15 & "
end if
if a16 <> c16 then
strBody=strBody & "Question 16: " & q16 & "
Trainee answer: " & a16 & "
strBody=strBody & "Correct answer: " & c16 & "
end if
if a17 <> c17 then
strBody=strBody & "Question 17: " & q17 & "
Trainee answer: " & a17 & "
strBody=strBody & "Correct answer: " & c17 & "
end if
if a18 <> c18 then
strBody=strBody & "Question 18: " & q18 & "
Trainee answer: " & a18 & "
strBody=strBody & "Correct answer: " & c18 & "
end if
if a19 <> c19 then
strBody=strBody & "Question 19: " & q19 & "
Trainee answer: " & a19 & "
strBody=strBody & "Correct answer: " & c19 & "
end if
if a20 <> c20 then
strBody=strBody & "Question 20: " & q20 & "
Trainee answer: " & a20 & "
strBody=strBody & "Correct answer: " & c20 & "
end if
if a21 <> c21 then
strBody=strBody & "Question 21: " & q21 & "
Trainee answer: " & a21 & "
strBody=strBody & "Correct answer: " & c21 & "
end if
if a22 <> c22 then
strBody=strBody & "Question 22: " & q22 & "
Trainee answer: " & a22 & "
strBody=strBody & "Correct answer: " & c22 & "
end if
if a23 <> c23 then
strBody=strBody & "Question 23: " & q23 & "
Trainee answer: " & a23 & "
strBody=strBody & "Correct answer: " & c23 & "
end if
if a24 <> c24 then
strBody=strBody & "Question 24: " & q24 & "
Trainee answer: " & a24 & "
strBody=strBody & "Correct answer: " & c24 & "
end if
if a25 <> c25 then
strBody=strBody & "Question 25: " & q25 & "
Trainee answer: " & a25 & "
strBody=strBody & "Correct answer: " & c25 & "
end if
Dim strSubject : strSubject = ctn & " Test Results"
Dim strAddressGroup : strAddressGroup = ag
Dim strFromName : strFromName = fn & " " & ln
Dim strFromEmail : strFromEmail = em
On Error Goto 0
Set Mail = Server.CreateObject("Persits.MailSender")
Mail.Host = Application("mailserver")
Mail.From = strFromEmail
Mail.FromName = strFromName
Mail.AddReplyTo strFromEmail
Mail.AddAddress "youremail@yourdomain.com"
Mail.AddCC "youremail@yourdomain.com"
Mail.Body = strBody
Mail.Subject = strSubject
Mail.IsHTML = True
On Error Resume Next
Mail.Send
if err.number = 0 Then
Response.Write "Email results sent succesfully"
else
Response.Write "Email failed to send
Response.Write "Error Number: " & err.number & "
Response.Write "Error Description: " & err.Description & "
end if
on error goto 0
Set Mail = Nothing
%>[/CODE][CODE]<%@ Language=VBScript %>
Dim strBody
strBody=""
if ts = "100" then
else
end if
if a1 <> c1 then
end if
if a2 <> c2 then
end if
if a3 <> c3 then
end if
if a4 <> c4 then
end if
if a5 <> c5 then
end if
if a6 <> c6 then
end if
if a7 <> c7 then
end if
if a8 <> c8 then
end if
if a9 <> c9 then
end if
if a10 <> c10 then
end if
if a11 <> c11 then
end if
if a12 <> c12 then
end if
if a13 <> c13 then
end if
if a14 <> c14 then
end if
if a15 <> c15 then
end if
if a16 <> c16 then
end if
if a17 <> c17 then
end if
if a18 <> c18 then
end if
if a19 <> c19 then
end if
if a20 <> c20 then
end if
if a21 <> c21 then
end if
if a22 <> c22 then
end if
if a23 <> c23 then
end if
if a24 <> c24 then
end if
if a25 <> c25 then
end if
On Error Goto 0
Mail.Body = strBody
Mail.IsHTML = True
Mail.Send
else
end if
on error goto 0
Set Mail = Nothing
%>[/CODE]
Still have not heard anything from Lectora support regarding submitting large amounts of data to google drive. Anyone else out there experiencing google drive issues?
@mgilbert 57670 wrote:
So I am assuming the method to implamenting this code is:
create an .asp file and add to course as an attachment
test properties submit to CGI using the file name.asp ensuring submit all variables is checked
then should work once published and test successful
First attempt failed so not sure what I am doing wrong
did you just put the code in the course as an HTML extension?
It's a separate asp file. It may not work as is. This took some help from IT guys initially. They got a version of this off the board. Not sure who posted it originally, but if they want to claim credit, please do. If you don't have persits on the server, it may not be able to generate an email, or you may need to change it to refer to another email sending program (or whatever it is).
Please, please, pretty please can Lectora fix this issue!!!!!!!!!!!!!!
mgilbert, wondering if you found a resolution to your problem submitting to the google doc? I also have a large 100plus test and want to send results to my google doc but get the same error you show below - however, at this point I am only TESTING functionality using a 5 question title! Any info would be appreciated. thanks!
