Go to Page in Title - example title using TOC and JavaScript
Simple Lectora Online implementation of a go to page in title using a TOC object and some JavaScript.
User enters the page number they wish to go to and press a go button.
By changing the scope on the TOC you could implement a go to page in chapter, test, or section similarly.
Import this Lectora Online title to see the example:
[ATTACH]541[/ATTACH]
Important note: make sure you change the variable of the entry field to pageNum if you copy and paste this example. You can type that directly into the entry field variable drop list control.
