Go to label Flash command not working
Forgot to add:When placing the cursor over (mouseover) the button with the go to label command, the status bar in MS Explorer says "javascript:void(null)". It neither works in preview mode nor in published course (local). I also want to use the "finished playing" (the Flash movie, don´t know what the condition is called in Lectoras English version) to show another Lectora object, but this seems to work arbitrarily. At one point Lectora decided movie (swf) had finished playing when encountering a stop() halfway through the main timeline. When the stop instead is only at the actual end of the main timeline, it does not consider the movie finished. How come? Thanks and sorry for long explanations ... hope someone can help. /Carina
